tel7726 wrote:I want to drop the shroud, rather than try to reach inside that little opening to change the oil and filter. I want to take a good look up there since I just bought this car a week ago. The dealer tells me that the shroud is held on by about 14 screws and at least one clip. I read the forum back posts about oil changes, but missed any mention of a plastic clip. Can someone tell me about this clip, if there really is one? Thanks, sam
It is a simple job to remove and replace. There are 14 or so 10mm small bolts. Use a 1/4 inch drive ratchet.
There is one plastic clip. It is near the front center. Use a small screwdriver to pop up the center & remove. Don't lose it. I use a cordless drill with an adapter for the 10mm socket. I have a 3 ton hydraulic jack & ramps as well as a rolling creeper to slide under the car. You'll also notice an old pink shower curtain that the wife was throwing out. It works great under the car with any minor splills or drips. The whole job should not take more than a half hour. I buy the oil filters at the dealer & try to find oil on sale (5w-30 Penzoil) at Pep Boys.
Have fun
Telcoman
