showin off
HansCC
Car: 1999 Y33 Cima
Finally getting more done -
Brakes done
FX45 rims power coated
new coil packs / plugs
fixed the o2 sensor errors - 2 aft o2 sensors
new michelins
I still need to get the center caps matched - keeping it simple -
now if I can figure out how to lower it 2 inches -
eQlipse
Car: 2006 Infiniti M35X
Are those the 20 inch FX rims? What size tires are you running?
HansCC
Car: 1999 Y33 Cima
These are 18's with 245 size tires - the rims are from 2006 FX45 with 40 offsets - there are typicall two types/styles of these - some have a flat blade without the end's being machined like mine and yes there are 20's out there - I elected to go 18's to save the ride - While this looks good I can only tell you that I have purchased 6 rims and 3 were bad and out of round trying to find a decent set of these. It's hard to fine 4 in perfect shape - just be aware that you are buying old rims and your mileage may vary. So far every advertisement I read seem to say all the same things - no bent rims and they are pristine! I am still working out the last rim issue. It would be far easier purchasing NEW rims but I wanted these - and it is turning into a project - :) Now if I can figure out how to save the ride and lower it 1 or 2 inches I will be happy - The car on my signature is edited in Photoshop and is not the actual car - just a look alike that is lowered.
HansCC
Car: 1999 Y33 Cima
I am ready to try bags -
