Show your FMIC piping setup
tight240
I dont know if anybody made a thread like this, i didnt have time to search because im at work.
I want everybody that has pic's of the front mount intercooler piping setup to post them, so i can get an idea of how you can do the piping in different ways. If you can, include what kind of pipes they are (steel, aluminum), how many different pipes you used ( straight pipes, u-bends, donuts, etc. etc. etc.) and the degree piping you used. I think this will help out more then just me but anybody in general trying to do the IC piping themselves.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
i am too lazy to find it, but if you look in the members rides section and search for my user name, you will see my pics of the installation of the hybrid FMIC setup. It shows you how all the pipes are routed.
backsidethree
Car: rb25det 240sx
I ran my piping from the left side of the intercooler over the top to the right side. (view atachment) If you do it this way be sure not to get in the way of the head light poping up. I used steel exhaust piping.
dekand
Car: 1995 240sx SE
wow never seen that routing before! cool stuff...
heres mine, pretty much the standard nowadays except my hotpipe goes behind the radiator where as most people have their cold pipe behind it.
ehacker01
Car: 1995 240sx
here's mine. I have the cold pipe behind the radiator. It'll be easier to redo just one side of the piping than two once I get a greddy manifold.
2.5" steel
krayton
old piping:
new piping:
lyon23
Car: 95 240sx
This is for one of the swaps I did.(that was an eclipse intercooler)this is with the bumber on.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
fly240
Car: nissan 240sx
krayton, that looking very nice. what turbo are you running?.....
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
dekand wrote:wow never seen that routing before! cool stuff...
I hadn't even noticed that the first time I saw it... that really makes a lot of since. You minimize your bends that way too... I can imagine all of the tight radius 90's and 180's involved in coming from one side reduce flow rates.
tight240
Nice job everyone, keep em coming
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
So is it possible to not have to relocate the battery with a fmic setup?
Yellow4g63
Yes, I didn't relocate mine. Your going to need a smaller battery tho. I have one of the Odessey batteries in mine as you can see by the pic.
ehacker01
Car: 1995 240sx
RB20DETodd wrote:So is it possible to not have to relocate the battery with a fmic setup?
Yeah, but why wouldn't you. Especially after the added weight of the RB motor.
Andrew85cm
Car: 89 240sx with RB20det
I just did my custom piping today. I got some group buy intercooler and it fits my 240 opening perfectly. I will post some pictures tomorrow. It took me 4 hours which is pretty fast imo to do it. I got 5 90 degree bends 1 45 degree and 1 straight pipe. I had 1 90 and the 1 straight left over. I reused someof the stock piping. I went across the radiator with my hot pipe like some of you guys. I'll get some pics up tomorrow. hope this helps a bit. I might try later to cut out some of the couplers and use more pipes but I didn't used too man I think I used 6 total.
~ANDREW~
240sxed
This is what i've been working on today, since i got my intake plenum.
Basically, s14 Greddy vspl, with tophat intake plenum. All the pipes pretty much fit, The hotpipe will fit pretty darn well. The cold pipe will need a 45 degree coupler and besides that it fits great in conjuction with the tophat rb25 intake plenum.
I painted the fmic black to get a little sleeper/stealthness and to avoid gettin cops attention as my buddy's neo6 has gotten the ref ticket.
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
That paint looks crazy thick on that IC. I think most people just spray 1-2 light coats and call it a day. I don't think it'll be much use as a means to cool the intake charge if you've killed the heat transfer with a thick coat like that...
240sxed
Used radiator paint, 3 coats not thick.
Yellow4g63
I like that can't wait to that to mine.
narfdanarf
kouki-gymkhana wrote:That paint looks crazy thick on that IC. I think most people just spray 1-2 light coats and call it a day. I don't think it'll be much use as a means to cool the intake charge if you've killed the heat transfer with a thick coat like that...
Yeah you use the radiator paint, my cousin did it on his civic and when we had it on the dyno (keep in mind not a lot of air moving across IC on the dyno even with the fan blowing) his intake air temps were not much higher if at all then when it was unpainted. Stealthy/Sleeper and still gets the job done right....
Thumbs up in my book.
240sxed
I'd keep my bling bling so bad...but cops around the bay suck ...california emissions suck. SF cops are cool though...to a point.
s13burger
Car: rb20 powered s13
These are older pics, I'll get some new new ones up in the next day or two. It's finished under the hood, except for the dump pipe coming off my turbo.
