I was curious to see what people have as custom headlight setups for the S13 or S14. Please Post pictures and include the following information as you see fit:1. Model : S13, S14, if you got it flaunt it.2. Type of Bulbs and relevant information. for example:
.3. Modifications: anything you had to do to get the lights mounted in the frame of the car. For exaple: Cut light brackets out and custom fabricated a new one to get the correct light cut-off angle.4. Custom wiring: any tips you may have for people trying to achieve a similar setup. IE: what wires go where to make them work with custom/stock switches.presidential wrote:6000k HIDs in some J30 projectors that I retro'd into some sealed beam eBay wonders. Yes, they still pop up and down no problem. Vibration is a minor issue though, I need to re-tighten the bump-stops so they sit solid again.
