Should You Change Your transmission Fluid: 2001 Pathy LE 4WD
Almatti
Car: 2013 M37X Premium Black Obsidian / Stone Deluxe Touring Interior
With 113k on the clock, should I change the transmission Fluid. 4WD service - yes. but the transmission Fluid & filter??? It's performing fine. "If it Ain't Broke, Don't Fix It??
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
Assuming you have an automatic... if you pull out the dipstick and look at the fluid, and it looks OK (not too dark, doesn't smell burnt, no particles, etc), then it should be fine to keep using.
That said, as a personal policy I change my A/T fluid every two years, filter every four years. I probably don't have to, but it's relatively cheap and easy compared to fixing a transmission. I'm anal about preventative maintenance.
Andrew224
Car: 2001 Infiniti QX4
2006 Maserati GranSport
2002 Harley Davidson VRod
You should. Don't do a flush, just a drain and refill. Open the drain on the bottom, and replace the same amount that came out. Can't hurt.
Andrew
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Yes, change your fluid. Should be done every 60K miles. As someone who's had a little trouble from my transmission, do it. You'll save yourself headaches down the road.
