this is from a thread i posted :zerothread?id=120906
I'll try posting it here.
Jehangir thanks for the input....
I had said in a post in this thread that it will not complete the self diag or self test... page 65 of the factory service manual...If I had a code to go with trouble shooting would be done and the part replaced or repaired...
I think Redman is coming through with new Active Control unit (Active CPU)I guess I have to wait for his CPU to see if mine is toast... mine was working before I ran dry on active fluid for a few days...
I had this issue before I changed out my 4 main accumulators... it went away after a week.... Texasoil says the CPU is offline.... I'm about to get my active suspension wire harness so I can install the Active suspension controller I got from Miniman...
I would really suck if I got the harness before I got the Active CPU back online...
I have found fuses #18 23 25 27.... page 59 Factory Service manual..
Does anyone (Q45Tech please help) know if a consult will still run tests if the on board won't complete?
It seems like the control unit must be working to run the self test.What about the consult if the Active CPU if failing?
Thanks for any input
