motoxris wrote:I completely agree with 240sx_ch08 on the "good enough" comment.
One thing with these bolts is that you real have to make sure they are going in very straight when you thread them in. I think I had to loosen up the links at the end of my sway bar. The tension pushing every thing around makes it imposable sometimes. If those are the correct bolts they should go all the way in. Period. When I bought my car those bolts were looser than yours on the front side. It made a lot of really bad noises, had bad handling, and very poor braking because of just that one thing.
If you have the wrong threads, it shouldn't be able to turn more than 3/4 of a turn.
I would triple check to make sure that there isn't isn't tension pushing around the sway bar. When I first looked at mine. I thought it was going to be way easier to install. It was all about making sure it was going in straight. And don't tighten everything all the way down until you have all the hardware installed about halfway threaded in. Then go back and tighten everything down.
Hmm, so if I jack the car up (to get rid of all that tension), and loosen the end link on the driver side, it should be able to screw all the way in?
Hmm, i'll have to give that a try. By the way, this is the way I installed it. I jacked the car up, slid the sway bar over the exhaust, and got it in place. Then I screwed in the D brackets and bushings about half way through the holes (to hold the sways in the position that it needs to be in). Then I lowered the car, and installed the endlinks, then I finish tightening the D brackets.
I just had trouble to finish tightening up the drivers side D bracket afterward. . . So you're probably right about all the tension coming from the endlink.
Thanks a lot, i'll give that a shot, hopefully that's the reason
Modified by Jagstang at 3:09 PM 10/2/2009
