From Motor Trend:
The Nissan GT-R might just be the most beloved member of Nissan’s lineup, and any radical changes to it are bound to be controversial. And what could be more controversial than the addition of a hybrid powertrain in the next-generation GT-R? According to our man in Japan, Nissan is considering that very option for the 2017 model-year.
Nissan has good reason to consider a hybrid drivetrain for the 2017 GT-R, as both American and European governments are cracking down on gas-guzzlers and CO2 emissions. Fitting the GT-R with an electric motor and batteries of some sort would help Godzilla retain its performance while still appeasing policymakers worldwide.
That said, Nissan is reportedly mulling over two powertrain options for the 2017 GT-R: a hybrid system centered on a 3.7-liter V-6, or a “turbo compressor and generator setup,” which would work with cylinder deactivation and stop-start technology to keep CO2 levels down.
Should Godzilla go green with a hybrid powertrain? Should the 2017 Nissan GT-R use the turbo compressor-generator set-up, or should Nissan go in an entirely different direction with the GT-R? Let us know what you think...
