BigBodyV wrote:You should defenetly worry, since its pretty clear you dont have a clue about engines... Sticking wires in there, wht is wrong with you?
I was sticking a wire in there that I had laying around, it wasn't a live wire or anything.. I needed something thin enough to slide in there to see if it was just a cavity that doesnt go anywhere or if it went into the lower end of the engine. I rather stick a wire in there and see rather then wait for water to get in there and really damage something,if it did go into the lower end. And for your information I dont know much about this engine but knew enough on my other cars to do most of the work needed myself. Also nothing is wrong with me. It's pretty clear you like to assume things.
