LayNLow240 »
https://forums.nicoclub.com/laynlow240-u33346.html
Mon Jun 18, 2007 8:40 am
vlsd is junk and wear out if you start abusing them.welded is fine for the street, its all about money and personal preference.welded is cheap, you either pay or do it yourself once and if done right requires no maintance ever unless it breaks. it makes a little sound, but so do aftermarket lsd's, big deal. pros of welded is cheap, reliable, consistant in lock up(since its welded)cons, if not done right it can break, noise when turning at like 5mph in parking lots(aftermarket lsd will also have noise) and a little jerking at that speed too when turning.aftermarket clutch lsd's will require expensive oil and you will need to change the oil when its reccomended, and eventually it will wear out, so youll have to get replacement clutch packs for it.pros not as much jerking, its a real lsd and its not locked 100% all the timecons expensive, loud(it knocks at low speeds, louder than welded) doesnt always lock the same on the same corner. requires expensive oil, needs alot of maintance
