Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Sat Jan 23, 2010 10:24 pm
Well, what I thought about his thread is what he got. I can be understanding, if the thread was titled "what do you think of this? VG30ET Z32". Or even "VG30ET Z32". But when you type up the title he did, and open with "check this out" followed by 11 more explanation points then needed it raises my expectations.
But you want my thoughts on the matter? Okay, pretty much what evildky said. I will go on to say that I do not have a completed swap of this nature to post up, mainly because I would not see the need to swap in a motor with the same potential. It's money best spent getting a new DE for the Z32.
As for what will swap over with the aid of a welder between a Z31 and a Z32, I'd say the entire rear suspension, rear end, differential. And the brakes. You'd have to figure out how to rig up the e-brake if you use the Z32 rear calipers. As for the front suspension, I don't know of anybody off the top of my head who has adapted anything there, but if you are creative enough you could probably get the coilovers themselves to work. The suspension arms, and such would probably end up like an S13 front swap, the geometry doesn't work out. I'd personally sell the fronts, and part the rest of the car out to offset the cost of putting coilovers (S13/Subie Stances with the weld on sleeve for instance) on the front of the Z31 suspension.
Or drop a good DE in the Z32 and drift that b****.
