Should I use a cooling system cleaner?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Rdsrds123
Car: 2018 Nissan Versa
Hi, should I use a cooling system cleaner after I drain and fill with distilled water? Then drain and refill a couple of times before I add New Nissan coolant? Does Nissan recommend a particular cleaner?
2018 Versa. 70k first coolant change
Thanks!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
We use Valvoline/Zerex Super Flush at the shop and it does a decent job, but at 5 years and 70K your blue coolant shouldn't be in terrible shape. Unless you have a specific reason, I'd skip the flush and just do a spill-and-fill.
Return to “Versa Technical Discussions”
