Should I take a free manual transmission from a z32?
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
So, wiring, clutch, and adaptor plate nightmares aside.
Would the Manual trans off a Z32, with an adaptor plate be somewhat compatible in the long grand scheme 10 year project of things with a q45?
Raxephon
Car: '04 RX8...for the moment...
Free parts for long term projects are always good.
RobertsnewQ
Is it the NA trans or TT? If NA, I'd pass.
G50 Q
RobertsnewQ wrote:Is it the NA trans or TT? If NA, I'd pass.
Why? I thought they are the same exact thing? lol
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
no they are different. The tt transmission is closer to the R32 GTR, the NA is closer to the 240...
They do have the same gearing though, but have different output splines and so forth.
John Dixon
Car: 300ZX-TT Z32
Not entirely sure about the differences. The diffs are certainly different, but I have a feeling the box's are the same. Been a long time since I saw an NA one though. Will do some checking!
Edit: The service manual shows the same part for both (RS5R30A) only difference being the oil capacity which I'm presuming is the extra in the cooling circuit for the TT box.
RobertsnewQ
Good to know...
Sure, get it
Buy an adapter from John Dixon when they become available.
How's that going, John?
elwesso
2007 BMW M Coupe
Really John.....?? I thought that if you had an automatic, N/A and you put in a twin turbo MT, you would have to change driveshaft, But you would not have to switch driveshafts if you had a turbo auto going to a turbo MT
G50 Q
elwesso wrote:Really John.....?? I thought that if you had an automatic, N/A and you put in a twin turbo MT, you would have to change driveshaft,
That's true but it has nothing to do with the difference between tt and na.
Any (tt or na) auto driveshafts are different and will not work on ANY (tt or na) 5spd trans.
Also, I did some checking and they are infact the same transmission, even though I guess that had already been established. lol
elwesso
2007 BMW M Coupe
Ok i guess I was wrong .....
Thanks for the correction.
John Dixon
Car: 300ZX-TT Z32
RobertsnewQ wrote:Good to know...
Sure, get it
About 3 weeks I think
