Should I?
0range_240
Car: 89 HCR32
Alright I know what your all going to say, and I would say it too if it was somebody else asking this... BUT hear me out first before I get flamed to a crisp
I found a pacesetter header being sold for $85 on the zilvia forums, it was used for a couple months, then re-coated with heat paint when the original paint flaked off... should I buy it? and if I do, all aesthetic problems aside, do they yield performance gains similar to other header brands like hotshot?
thanks :pface
[s3]
$85 cheap, if you don't mind the hassle of it rusting off and fixing it up later.
performance yields are pretty much the same + or - 1 or 2 hp
0range_240
Car: 89 HCR32
well like I said it was re-coated with high-heat paint so I doubt rusting will be an issue now
Ive got my own shop and all the welding/repair skills I need, im just concerned about performance at this point
[s3]
You will have to see for yourself then,
performance difference is neglible between brands
0range_240
Car: 89 HCR32
alright, thanks =D
0range_240
Car: 89 HCR32
anyone else got opinions on this? bump
