Should I swap my 19-40s for 18-45s?
Valenti
New guy here. I was considering asking the dealer to swap my 19 inch 40s for 45 series 18s to help the ride a bit. Yeah I know, it's not supposed to be a cushy sedan and that the lower profile tires probably contribute to the car's oustanding handling. But we've got some nasty roads up here and I thought perhaps a slightly taller tire would offer a better ride.
Comments from the experts welcome!
Valenti2005 6MT
Valenti -
Welcome aboard!
I would think the 18's will offer you a bit more protection against the harsh roads there in WA.
If you're interested, I will have a set of OEM 18's with new tires available in a couple weeks, and would LOVE to swap for some OEM 19's...
Valenti
GregI may take you up on that offer (which tires on on those 18-inch rims? How many miles, etc?
Related question: So I've read (with some concern) about cupping and feathering problems with G coupes. The posts seem to refer to the 18 inch wheels. Is this an issue for the 19s as well? And is this a common problem or just for some folks with certain tires under certain conditions?
Thanks!
They have Michelin Pilots, 245/40ZR18 I believe... A bit more sidewall, a bit beefier tire. They should have about 3-4K miles on them by the time I drive it home from Atlanta.
I'm told the cupping / feathering is a car issue rather than a wheel size issue, and I'd be VERY surprised if it was as common as it sounds.
rydwhite
Car: 2003 Infiniti G35 Coupe
The issues with cupping and feathering have been more in lines with specific car suspension set-up. There seemed to have been some issues with the amount of rear camber in some cars. This has resulted in some odd tire wear. I had this problem with the 17's on my coupe. Since I have adjusted the set-up, I have had no problems with odd tire wear.
Valenti
RyanThanks for that tidbit. One would "think" the dealers would know this and make sure the camber/caster/alignment is set up properly to begin with. An ounce of prevention here would save a lot of customer grief down the road (pun intended...)
rydwhite
Exactly.
