Colton »
https://forums.nicoclub.com/colton-u28943.html
Mon Aug 15, 2005 3:47 pm
I don't often post on forums, but I live in Minnesota and can rarely find anyone to trust (information wise).
I recently tuned my car at 18 psi (give or take) for 400 whp at 7000 rpms with A/F around 11.6-11.8
I haven't built the bottom end of my motor (stock rods, crank, and pistons). Yesterday I pushed my car to 23 psi (while messing with the boost controller) and revved to 7500 rpm. I was scared at first, but I showed no knock or over heating of any sort (egt, coolant). I want to know where the breaking limits are on this engine. I don't want to blow it up yet, but I would like to put down 475 whp (I know I can hit it, but how long can it last) and run 11's by the end of this year.
My mods are as followed.
top speed intake manifoldHKS step 2 264 ex. and in. camsHKS adjustable cam gearsHKS 2.0mm headgasket (yes I know it's thick)HKS valve springsported and polished headPrecision Turbo SC-61ssautochrome top mount tubular manifold, modifiedTial 38mm wastegateGreddy front mount intercoolerUnorthodox Racing crank pulleyApexi N1 exhaustcustom 3 inch down pipe and test pipeNismo 740cc injectorsRedline Tuning ECUApexi SAFC 2Nissan Z32 mafs
When/If I tune for 450-475 whp where should I target my A/F ratios? Does anyone else here have similar power levels that have been running for awhile? What is my limit (whp wise)?
I typically drive at 14-15 psi so I wouldn't be hammering on my car all the time. I would probably boost it hard once a month at the track (drags).
Please help me out!
