300sx wrote:I am looking to replace my valve cover gasket in a few weeks because it is leaking from all sides. Should I use seafoam prior to replacing the gasket? Would be wise to do so since it'll clean the internals and what not.
Those 2 are not related, so you can seafoam it later or before.
300sx wrote:Also, is it easy like everyone else says to replace the gasket? I've searched and a lot of people are saying its a 30 min job. I have never touched an engine in my life . It'll be the first time for me to open up any engine compartment. Which tools will I need to do this and will i need to remove the hood of the car since one of the bolts are near the firewall.
I can give you some tips on this.- Get an FSM(Factory Service Manual) and follow the steps when you tighten the bolts.- Follow Torque Spec- Buy black RTV and use it on half moon area- No need to remove hood
300sx wrote:And what is the best method to clean the outer side of the engine where the leaks are?
Try brake cleaner. Works like a charm. Or any degreaser should work too.
