you got 210 hp w/ that setup up there??? to the wheels or crank? If crank, what was the dyno to the wheels. Can you post pics of that dyno.
It's just really amazing to see that much gains from essentially these mods (intake->exhaust, underdrive pullys, and minor engine work) and that guys who have totally built up the DE w/ more than what you are listing (lots of internals) are only hitting about 175whp or so.
I'm not doubting you much, I just find it astonishing that you are making that much power (if it is whp).
highkck wrote:Jim Wolfe ECU TuningHotshot 4-2-1 HeaderMagnaflow High-Flow Cat.Custom 2 1/4in. CatbackInjen Intake Cold AirMaxbored Throttle BodyComplete Port and Polish Job on the Intake ManifoldUnorthodox Pulley SetAgency Power Underdrive Throttle Body PulleyIm also running lightened driveshaft and flywheel which should play a key.
