onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Feb 03, 2006 10:16 am
Dood,
1) The reason you are on the "chopping" block is because most of the stuff you were listing are not hp adders - maybe a couple of them are for reliability/etc, but not hp adders.
2) We want a dyno chart because that is what pretty much 100% will justify colder plugs or not. Running colder plugs in a car that doesn't need it will take away power and work oddly. If you say you dyno your car & want to know if you want to run cooler plugs (which is based on hp increase), then we want to see the dyno #'s, not what you guess is your hp. Whether it's off or not isn't the point, we need a good basis/foundation to give you advice.
3) Ppl don't normally talk in crank hp on this board, and estimating your power from a quarter mile time is "okay", but that's not accurate.
4) About the radiator, a few fresh alloy guys did some independent testing on their sr's (not same as your setup, but you can extrapolate) and found that the stock radiator cooled better for a variety of reasons
5) If you are going boost, you should NOT be running n/a cams period. Those will work against you when turboing.
6) If you are wondering if you should run cooler plugs or not, I already answered this question that you posted on the other sub-forum, as well as most of the members here.
Until you can actually provide us w/ the dyno chart, which is what we will base our decision on whether or not you think it's accurate, the answer as you should have read through all these posts is a resounding:
No, it will not help you.
And to let you know, acting defensive and not taking proper criticism won't get you very far on this board.
And ppl are going to be mean on forums, deal with it, I have.
