EM.TT »
https://forums.nicoclub.com/em-tt-u175276.html
Mon May 27, 2013 8:22 pm
I'm in a similar position right now. After disassembly and some measuring I'm only honing and doing rings, lapping the valves, and cleaning the heads with some porting. All my bearings, journals, pistons, cams and even most seals were all good and within spec, but it was also a "low mileage" JDM engine that I happened to really score on. Also, basically everything besides the internals are new so that helped with total costs quite a bit. Not sure if that helps but similar scenario in a way.
