sebazztard »
https://forums.nicoclub.com/sebazztard-u58647.html
Fri May 15, 2009 5:14 pm
kade swap + mild turbo setup
the vg30de (which im assuming you are referring to) swap is completely pointless, tt i belive will have to be converted to single turbo because of the space, and the na vg isnt very impressive, even with all the major mods, including tuning. you will be lucky to get 200-220 TOPS to the wheels with a fully built na where you can get that with just a simple turbo setup, even on your sohc. this doesnt even include how much time and money it will cost for you to fabricate everything, source all your parts, wiring, etc..... with that said, im not going into what motor you should use, but just because its a z motor and a v6, its nothing special, unless its in a z32 because they are sexy.
