iheartu wrote:Not to jack you thread but I just have one question. Why would you say to rebuild you ka yourself? Is it expensive to have it rebuilt or do shops just not know what they are doing?
Shops in general are expensive. I rebuilt a KA a year ago for a turbo but didn't know what I knew now about the motors and I foolishly took the quick way out which cost me a motor. I rebuilt that thing last April and just did an engine swap last week to correct the mistakes I made so long ago, my s13 sat for almost a year. It's not hard to rebuild at all. The only annoying part is timing the motor. (at least it was annoying for me). Just takes time, so make sure you have the place to do it, the tools and the time. You want to change the bearings and re-ring the pistons are just get OEM pistons, better yet if you want to turbo the car it would be wise to replace everything @ once. pistons, rods, gaskets, bearings, new timing kit, metal HG make that sucker a brick for under $1500. Just remember putting a turbo on a old worn KA is gonna cost you in the run, so get ready to spend the same $$ on a turbo KA as you would an SR, course the KA block would be much more sturdy and produce more power depending on what turbo you get. Goodluck.
