EviL inside »
https://forums.nicoclub.com/evil-inside-u43933.html
Wed Apr 08, 2009 5:24 pm
line "fabrication" is no big deal. i had a 90 sx with a de swapped in. i kept the original evaporator and drier/accumulator, used a condensor from the 93 donor of the DE motor, and the bracket and compressor from a 96. the only line that had to be made was the low pressure line from the firewall to the compressor. the "fabrication" involved taking the compressor side fitting and firewall side fitting to an A/C shop and telling them how long i needed it. $30 and it all worked.
for an SR, CA, RB, the MOST that would be needed is TWO of those lines. the one from the compressor to the condensor, and the one from the firewall to compressor. nothing else is needed, even for R134a operation,,,the 90 (which originally used R12) used the EXACT SAME expansion valve as the 96 (from the factory with R134a), and the design of the condensor, evaporator, and accumulator/drier is virtually the same, just with slightly different mounts and fittings.
it's easier than people make it out to be. i've done it, and i'm a cheap a**
