should I go with double platinum plugs or iridium plugs
cellysel
Car: 2001 Nissan pathfinder
I've never done a tune up on my pathfinder , how hard is it and what do I need besides the spark plugs and air filter ?
My pathfinder is running perfectly fine . What type of spark plugs should I use iridium or double platinum? The double platinum came with the pathfinder but I've been hearing that the iridium plugs are just as good and last longer and are less expensive. :dblthumb:
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
Which engine do you have? The 3.3 has a rotor, cap and wires, so changing those would be included in the tuneup. The 3.5 has ignition coils atop each plug which, unless you have a misfire, don't need to be replaced.
Obviously, I would also check or replace hoses, air filter, and belts.
cellysel
I have the 3.5 wit the coil packs and it's not misfiring , changed the air filter already and I'm planning on changing the belts. Should I stick with the double platinum spark plugs ? Or go with iridium?
eduJ
Car: 1998 QX4
I would just stick with the standard plugs that came with the car. The difference, if any, is negligible at best.
atraudes
Car: 2001.5 Infiniti QX4 4WD
Agreed, your best course of action is to stick with the recommended NGK PLFR5A-11. People here have had problems with different brands/models.
Car: 2001 Nissan Pathfinder LE
Dido, go with the NGK PLFR5A-11..Jus did mine took me about 2 hrs to jus basically remove some stuff outta the way on both sides. driver side is a bit more work
cellysel
Does anyone have feed back on the autolite double platinum plugs , my mechanic is planning on installing them tomorrow. Unfortunately the supplier is closed tomorrow so we can't exchange them for the ngk's
eduJ
Car: 1998 QX4
The only advantage with regards to platinum or iridium plugs is its longevity. In fact, copper plugs have the best performance because of its conductive properties. For me, I rather stick to copper plugs and change them out every 20/30 miles or so. No biggie.
