captainzeros wrote:You might want to consider an electric fan, if you're doing the radiator and water pump anyways. My plastic fan lost a blade and I couldn't find a reasonably price replacement so I installed a fifteen dollar ~13" electric fan from a junkyard Geo Metro designed to go on the front of the radiator (managed to wedge it between the radiator and the front grill quite nicely in fact) and haven't had any overheating problems in up to ~100 degree weather. On the up and up, too, it actually revs a lot more responsively without that big slug of spinning stuff stuck on the belt. I have mine wired up with a relay to be on when the key is on the on position, I figured I don't care enough to bother with temperature controlled shutoffs and such, it would be an unneeded complication for my truck.
That's my personal opinion after doing it anyways, all around your list looks great and pretty comprehensive. How much is the guy asking for it, out of curiosity?
edit: I'd be tempted to use a bigger fan or dual small fans for your climate though, around 100 degrees is the hottest my truck has encountered and it's my understanding you'll get more in Arizona.
Good idea about the fans. I would just wire them to be on constantly here. Even on the hottest day, my current 720 never goes past the 1/2 mark on the temp. sensor. I also put a bottle of "wetter water" with the new coolant too. It's supposed to reduce the temp. by %20.
The guy is asking $1250, which is much more than what I offered him. He says he needs the money, so I'm hoping he'll get more desperate as time goes by.
