I don't think your cat is backed up. You would be seeing major loss of power with a downshift at higher speeds. Plus you would more than likely have a CEL on. If not, then your cat is fine. The most likely reason for your exhaust turning colors is oils. If you or whoever installed them without gloves, then there's where your discoloration is coming from.Blazingwolf wrote:my cat is backing up cause my greedy pipe is turning purple.
Agreed on the color change, but, stainless should bronze. When I installed my headers they turned a nice bronze color. My mechanic and I used gloves on them. One day some idiot put his finger on my header and I did not realize it until I ran the motor. So, I had one blueish purple fingerprint on my front header.Blazingwolf wrote:stainless steel turns colors above 270 degrees.
oh im still getting a high flow cat.. im hoping for a top end gain
The only choices for pulley's that I know of for Maxima's are either an "underdrive pulley" or a "light-weight pulley." The underdrive pulley is a smaller diameter than the stock pulley and will "underdrive" your electronics and will help get the rev's up much quicker. The light-weight pulley is the same diameter as the stock pulley but being lighter uses less rotational mass and thus spins quicker as well. I'm not sure about which would give better gains, I would assume they would be pretty close to the same. I have an Unorthodox underdrive pulley on my Maxima, so did Jeremiah.Blazingwolf wrote:i think i will get a pulley
