Neil »
https://forums.nicoclub.com/neil-u15642.html
Wed Mar 08, 2006 6:08 pm
Itll work but supposedly according to the fsm it won't be 100% accurate. Probably not enough to make hardly any noticable difference in drivability honestly. In regards to idle, the manual says unplug the tps, get idle to 700rpm, then adjust timing, then plug it back in. Im not sure why it jumps around 1000rpm... thats a lot, but it probably has something to do with going in and out of 'timing set mode' (unplugging and re-plugging in the tps)
only thing i can think of is verify #1 top dead center with a long screwdriver down in the plug hole in comparison to the pics in that link i mentioned. that'll at least let you confirm weather the chain jumped a tooth or not. I feel it is very unlikely that it has jumped.
Do you know anyone else with an SR? Can you borrow their cam angle sensor?
If you want to take it to a garage, dig up all the right factory settings for the motor and any reputable mechanic should be able to diagnose it. just 'cuz its an SR doesn't mean its different than any other motor... they just may make you sign a waiver saying theyre not responsible for it.
I like to help but its late so im going to bed. Let us know how the tinkering goes.
