Postby
Bigbux31 »
https://forums.nicoclub.com/bigbux31-u231279.htmlWed Feb 05, 2014 7:10 am
I own a '07 g35S and I'd like to paint the grill black and the emblem the color of the car http://tinyurl.com/pcavjwb what do you guys think? Other suggestions welcomed. Thanks!
Postby
370Z/28 »
https://forums.nicoclub.com/370z-28-u126175.htmlWed Feb 05, 2014 8:45 am
IDK, I think it looks good the way it is. If you wanted to start a whole blackout thing, you would have to go all the way.
Check out dipyourcar.com and look at the Plasti-dip. You can just peel it off if you don't like it. It is real easy to work with. I did the emblems on my car.
Postby
audtatious »
https://forums.nicoclub.com/audtatious-u2438.htmlThu Feb 06, 2014 5:19 pm
It should be fine any way you want it. As mentioned above you can try Plasti-dip "just in case" you may want to remove it. Else make sure you prep the plastic before painting.
