Should I buy this 240?
do it?
Yes
1
100%
No
0
No votes
Total votes: 1
PMLyf
Car: 96,96&97 vw jetta
Found a 92 with a ka24de swap ( it's auto sadly)
The main problem is that the car idles above 2000 rpms. I've already did some searching and I know a think or two about fixing cars. I just wanted to get a few.opinions before I dump the cash on my first 240. I didn't get to drive it but supposedly it has a hard time getting into drive because the idle is so high, and once it's in drive the high idle will shoot the car forward (can't be good for the trans right?)
Anyways, the guy wants 1500, what do you think?
Also I'm new to the forum, been a member for a while but just to lurk the classifieds. Hello.from Florida =)
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
ka24de swapped 92. :slap:
PMLyf
fiznowler wrote:ka24de swapped 92. :slap:
Sorry? Do they come the ka 24de originally?
TerminalVelocity
Car: 1996 240sx
yes 91-98 have the ka24de stock.
Fyi, my car had an excessively high idle as a result of the coolant temperature sensor going out on my 95 a few years back.
PMLyf
TerminalVelocity wrote:yes 91-98 have the ka24de stock.
Yeah I read that could be one of the issues. Guess it's worth 1400, going to go ahead and tow it home. Don't think 30+ minutes of driving it would be good for the trans with the idle that high.
mechanicalmoron
It shouldn't matter at all once it's moving.
Put it in gear on a slope, when you're rolling about ten miles an hour. (Assuming you can put it in neutral first, without hitting drive.... I really don't know how the auto is set up. Or how any auto is set up) Just avoid traffic lights, those might end badly.
You could also adjust the IACV all the way down, and probably get it down to a normal fast idle. In fact, that might be the only problem. Let it warm up to see what it drops to first, and when it's fully warm try to adjust it to 7-800. Bring a screwdriver for said adjustment, but make sure to complete the deal before doing the adjustment.
Because 2k is like 700 high, and I think you can get it to like 1300 when hot, with the IACV. That means it COULD just be the IACV, and if not, you'll still be able to get hot idle down below normal fast idle.
The fact that it's had it's stock motor "swapped" either tells you that somebody doesn't know what they're talking about, or is trying to rip you off.
I'd offer lower, on account of him taking you for a sucker and telling you it's a ka24de swapped 92.
Last edited by mechanicalmoron on Mon Feb 18, 2013 9:19 pm, edited 1 time in total.
BTL_nissan
Car: virgin 93 240sx s13
Just jew the guy. Bring him $1000 and if he says he can't do it.... Leave. He will call you back. Unless your in a heavy tuner area. Either way 1500 for a running 240 is cheap. Around here anyways. Keep in mind its an auto so there is less of a chance its been ragged as hard as a manual would have.
