should i buy
Nissan dominates the drift scene - Always has, always will.
ozzfan
Car: nissan 240sx
Should i buy a 350z or a 240sx for my first drift car, learning with it.
mxkilla450
240sx is cheaper . just weld the diff and slide it .
ozzfan
Car: nissan 240sx
weld the what? newb here.
adrianfromthecastle
Car: 1992 Nissan 240sx
ozzfan wrote:weld the what? newb here.
weld the differential...
if you don't know what the differential is... you have a lot of reading to catch up on.
read here first: zerothread/139711
but for the most part, I agree with mxkilla450
SR24DET
Car: RMS13
I agree. If you really wana drift, start with a crappy car. Too many people make these super nice cars to learn to drift with, then they get to scared to mess them up and either puss out, or take it easy while learning. Get a cheap POS 240sx and weld the diff and go to an event to learn. Beat the crap out of it learning and if you mess it up you wont care.
phanatikz32
Car: 1991 NA to TT z32 biatch!
if you dont know what a diff is then buying a z33 will be a gross waste of money. buy a MANUAL s13 and dont weld the diff. learn about cars and how they work while you practice on an open diff 1st then move up to a welded or 2 way. think of it as strength training. using the stock open diff will be like running with 20lb weights when you get a 2 way or welded then it'll be like dropping the weights. starting out on a tough car to drift will make your life easier later.
s13_maJiK
Car: s13
Hit up the FAQ section and read a little bit, you'll learn alot.
Return to “Nissan Drift Forum”
