BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Mon Nov 04, 2013 9:52 pm
I would seriously consider having a mechanic look at the car. While 3k isn't a lot, if the timing belt, water pump and while you are there cam seals need to be done, that is just a start. Then you could have issues with the transmission, turbo, power steering rack starters, alternators, etc. That doesn't mean the previous owner hasn't already dealt with those issues.
My 84' with 165k on it has had 3 timing belt overhauls that included the cam seals and water pump. I have also had to rebuilt the transmission, replace the power steering rack, alternator, starter, EGR, catalytic converter radiator and belts and hoses. This is not out of line for a 29 year old car. I have NOT ever had to rebuild the motor.
Post up your location, add that to your profile so we can tell where you live. Maybe there is a shop we can recommend depending on where you live too.
Last thing, mother rust. If the car doesn't have any rust I would be very surprised. To look for signs examine the outside of the car and look for obvious rust. Then open up the rear hatch and pull off the spare tire compartment on your right side with the little plastic bolts. now remove the spare tire and see what you have. 99% of the Z's out there have rusted in this area. This can be repaired by a body shop by cutting it out and replacing it with stainless steel and then undercoated. While my Z was a garage queen for nearly all of its life, this rusted on me. But the main frame rails, outer body etc have never had a lick of rust.
Best bet for 3k is to find out what they can show you in terms of work done, post that up here along with your location...inspection would be a good idea, not because your spending 3k on a car, hell I spent 3k on the Leather Digital Package in 1984 when I bought my Z (I know my car is older than you are) but the additional 3k you might have spend afterwards, or maybe just timing belt stuff which isn't that bad.
