elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue May 28, 2013 11:50 am
First of all, a 21k mile Z, even an N/A automatic would probably be worth at least 6k, so the price is scarily low. I would check it out VERY carefully, if you're not comfortable doing that take it somewhere and have it inspected. There's really not a lot special about the Z. if it's truly got that low of miles I'd be concerned about checking to see if it's been in a wreck, flooded, or something like that..
Before you drove it any length of time, I'd think you'd want to change the timing belt. For sure at 21k it's probably not been replaced, and I wouldn't go too far on a timing belt that's 23 years old. Really for that matter, you're still going to need to replace a lot of wear components like hoses, belts, bushings, dust boots, and so on. If everything checks out, it's probably still worth 5k as it sits if the engine and transmission are good.
