Should I build my head?
elpiar
Car: 1992 KA-T
As long as I build my internals (aiming for 350+ whp) do i need to build my head? My understanding is that building head is more for high revving (if the car is to be raced, not street) or if going all-motor.
help correct me if i'm wrong
KATwo40
Car: 1993 240sx KA-T
Begin with the nose, which is the most important part.
Then, move on to the ears and eyes. Once those are in order, the eyebrows and mouth come together easily.
J/K. I wouldn't build the head for sub400 whp applications.
elpiar
Car: 1992 KA-T
thanks. any other opinion?
lrb_2000
Car: '91 Nissan KA-T hatch
i'd probably REBUILD the head.. maybe not new valves, but valve stem seals and such.. maybe a set of cams.. and minor port and polish.. it will just allow you to hit the 350whp range a little easier.. maybe a little less boost?
KATwo40
^^^ Agreed. If the engine is already apart, give the stock head a nice refresh. You won't regret it.
elpiar
Car: 1992 KA-T
Can someone give me a list of parts I should replace as I rebuild my head, say for a head with 100-130k mileage?
Also, suppose I want to "semi-build" the head, what should I prioritize?
s14det
My engine had about 60K-70K on it before I rebuilt my engine after a ring land let go. My engine builder was doing a 3 angle valve job and port and polish when he said I needed new exhaust valve guides. The intake side looked fine, just the exhaust side would need to be replaced. I would Def. look into replacing your valve guides since the head is already off.
