n1sm0r wrote:VLSD doesnt need anything special. DO NOT BUY LSD ADDITIVE. The vlsd works completely different from clutch type lsds which is what the additive is designed for. You can safely go with any 80w-90 Gear oil.
Synthetic would be nice but its not necesary.
I used cheapo valvoline 80w90 in my vlsd until i sold it and got a clutch type. Now i run redline shockproof gearoil.
well..you would be wrong. The viscous coupling as well as the other componenets of a VLSD require the silica (IIRC) base compound in the "additive" to function correctly over long periods of time. Sure it "will work" without it, but you'll be slowly doing harm to your diff the entire time.
Rule of thumb: If Nissan puts it in there OE, there's a GODDAMNED good reason for it. IF you honestly think you're smarter than the guys who designed the mechanichals of the car, you're definitely smarter than me. Sealed or not, the LSD additive is for use ina VLSD.
Most higher-end synthetic gear oild already ahve the additive in it or it will say "compatible with limited-slip differnetials" or some other such markings to elt you know. Redline shock proof, I know for SURE has this already in it.
also "API GL-5" type fluids have the friction modifiers (essential for most LSD function) you need, and the ones reqired for certain trannies to function.
Not using the correct type of gear oil/modifiers in your diffy would be like pouring GL-5 into a GL-4 transmission...it won't immediately go wrong, but after a couple thousnad miles you'll be going "hey..this doesn't feel like I though it used to..."
a few more thousand"what the heck, why isn't it working right?"
take it for what its worth.
-Chet
