KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Fri Jan 09, 2009 8:11 pm
just pull the turbo, take it to a local diesel mechanics shop, or a local shop(shop specializing in aftermarket stuff)
and have them rebuild it, a rebuild kit is cheap, under $100 then labor.
first, pull the turbo intake off, reach your hand inside to the sahft and grab it, and wiggle, to see if it has "shaft play" if it is excssive it seals/bearings, which is in the rebuild kit. its normal to have a tiny bit, but should NEVER touch the housing, blades and housing should not com incontact with eachother
