Should I attempt stock Autocross
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
I was thinking... its light enuf small enuf and quick enuf why not give it a shot?
PEZi
i voted for using a different car... the reasons being
1. you will be in H-Stock... not a fun class2. stock... the handling just isn't there3. if you're at stock ride height... they may not even let you compete due to possibility of rollover4. the hardbody is not as light as you think
if you play around with it a bit and move into F-Street Prepared you may do ok... but stock autocross in trucks is no fun..... if they even let you do it
kibatheloanwolf
PEZi720 wrote:i voted for using a different car... the reasons being
Well i want it to be able to haul things still but if i do tweak what would you suggest?
JC87HB
Car: 1987 Nissan D21 HB
I suggest getting your truck lower to the ground and stiffining up your suspension.
PEZi
^ that
lowering and stiffening need to occur to autocross a truck... also a decent exhaust and some camber up front... typical power mods and basic suspension mods are legal in FSP and that's what you should go for
oh and don't forget a sticky-ish tire
kibatheloanwolf
Okay..But what mods are there for the 2.4 liters? I looked all over Google for them but I didn't find even one..
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
All kinds of mods. You need to dig deeper.
http://www.nissan4parts.com/SC...g.pdf
kibatheloanwolf
Ah... Lowered the rear a few inches and getting new tires soon
PEZi
i assume you should be good to run from a safety standpoint lowered and on new tires... you can run in ST. you won't do good though... that class is dominated by old civic hatches
