Al Dave »
https://forums.nicoclub.com/al-dave-u102338.html
Mon Apr 20, 2009 11:25 am
Just changed the timing belt in autoshop. Looking at the kit obtained from the infinitpartsusa posted in this forum which says:
This is a complete timing belt kit for the 1993 J30, which includes: A172M-0P5SMVW ASR 1 BELT-FAN A192M-0P5SMVW ASR 1 BELT - COMPRESSOR A195M-F65SAVW ASR 1 BELT-POWER STEERI 01001-00191 2 SEAL-OIL,VALVE 12333-F6500 1 PLATE CRANKSHAFT 13028-45P86 1 BELT-TIMING 13042-16V00 ASR 5 OIL SEAL-CAMSHAFT 13070-45V04 ASR 1 TENSN BELT 13072-45V20 2 SPRING-TENSIONER 14055-F6511 ASR 2 HOSE-WATER,BYPASS 21010-0P529 ASR 1 PUMP ASSY WATER 21200-42L06 ASR 1 THERMOSTAT ASSY 999MP-A7007P 1 GASKET SILICONE L
, I dont think that the mechanic really changed all this things. When I picked up the car they just showed me a belt and said they had to change the coolant. While picking they said the car had other problems. they check engine light is on. I said if they checked, they said no. I told them I did not see such a thing. They said, when I left it was on. Then when they started the car, I saw no check engine. The two mechanic spoke to each other in some European language. From their body language, and some words, I could understand that one of the mechanic put something in the wrong way, the other one later corrected it and thats how the check engine light went away.
I got a bit worried, because, now I could understand that the check engine light came due to their activity and just no to take the responsibililty they said it was there before. Because I am very consious about the car. I can do minor repairs but timing belt in an interference engine is over my level.
When I picked the car the cars idle behavior has changed. It seems to be shaking after every few seconds. I told them about this, they said they dont see any problem. They charged $500 for doing it. Now I am not sure if they did correctly or not. I asked them about pump, thermostat. They were like, are you kidding me.
I was wondering why the car idle response changed ?And also I felt that in the auto gear when it changes from gear 2 to gear 3, I feel a different behavior, a sudden shift. What could go wrong chaing the belt
That was yesterday,
Modified by Al Dave at 5:49 PM 4/20/2009
Modified by Al Dave at 6:12 AM 4/21/2009
Modified by Al Dave at 6:13 AM 4/21/2009
