ianae86 »
https://forums.nicoclub.com/ianae86-u66623.html
Tue May 29, 2007 12:50 pm
Alright, so i've been trolling around here for a while but only recently signed up since the outcome of my trade looks promising. I'm trading my '93 Honda Del Sol for my friend's '91 240sx plus cash. The Sol is in great shape, runs like a top but his definitely needs some work. It has a little over 200,000 miles but still pulls strong. Just had a new clutch installed with slave/master cylinders. The water pump was changed not too long ago by the owner before him. New battery and some other basic stuff. There are some concerns to me though and this is where maybe you can help me out 1. The coolant overflow container is busted open. Not much coolant inside obviously which leads me to believe the thermostat must be removed? Any idea on the cost of a container from nissan? And I've been reading about changing the thermo...never done it before but doesn't sound too hard.2. The shifter is sloppy. Has alot of play in it. I read about the bushing on the bottom of the lever that can be replaced. Any idea on cost of this from Nissan? Pretty easy job as well? 3. The valve cover gasket leaks a little. Obviously not too big a job but I see alot of horror stories of over-tightening. I dont' have a torque wrench. Should I invest in one or if I just don't go crazy with my "muscles"(6' tall, 150lbs :P) should I be all right?Thanks for letting me rant and rave. Here's a couple pictures of the car...and my Del Sol. Excuse the crappy pics, was just playing around with my fisheye.
