shotpeened rods?
2-40oz sx
Car: Drum instructor
Hey do anyone know how much power a shotpeened ka24e rod will handle?
WDRacing
Its hard to estimate somthing like that. Lets say you have the perfect fuel mixture with no detonation. As you steadily increase the boost the hp is rising. All of this being done on a dyno.
Assume you make 400hp at the crank, then as you add 1 more psi of boost you bend/snap your first rod. Now does that mean the limit is simply 2 psi lower for around 380-385. Or was there sufficient stress to snap a rod there as well? You simply didn't run the engine at that power range long enough for the stress to take its toll on the rod.
I'd venture to say 400hp would be a safe zone for shotpeened rods. But again, thats assuming you have everything perfect.
WD
TrunkMonkey
Car: 2000 Lincoln Navigator
btw, KA rods are already shotpeened from the factory.
-demetrius
95_240sx
Car: My baby (car)
Boost it till it Blows!....
...or spend $700 and buy Crower rods
Rick
Turbo_Nismo_EC
Car: My truck...of course
I'd actually like to know the same thing. When I had my engine assembled I installed new forged pistons, but couldn't find an affordable set of rods to fit the stock piston pin, as in I couldn't afford to buy the Corrillo rods and have them bushed to fit the stock pin size in the piston. Well..I didn't know of another rod at the time. Anyway, I had the stock rods worked, as in checked, polished, balanced, and shot-pened..as well as ARP bolts installed. I know the pistons can handle high hp, and so can the crank, but I am curious about the rods...given the a/f ratio is dead on perfect, or a slight bit rich.
Turbo_Nismo_EC
DEMCJ...I heard somewhere that the KA rods are forged also because they are so long also, is there any truth to this??
TrunkMonkey
Turbo_Nismo_EC wrote:DEMCJ...I heard somewhere that the KA rods are forged also because they are so long also, is there any truth to this??
yup. the rods are forged from the factory.
-demetrius
DriFt3r
Car: Racing and Drifting
where did you buy the arp bolts for the rods?
machinehead
rods are forged from the factory. get em repolished and balanced then cryo treat them. should be fine. if you need more power then that, well you should be spending money on an rb silly head :p ;)
90lkn4swp
Car: putting rounds down range / and gettin back home so i can drive again
machinehead wrote:if you need more power then that, well you should be spending money on an rb silly head :p ;)
I dont know abut that id personally like to keep the weight ratio if not make it better than the 52/48 w/ka btw does anyone know the w/r with the RB series?
