1.8turboterror wrote:i knw alot of people use 300zx is that a tiny bit shorter?
I can testify that is is exactly the same length if not a little longer as I can use the same equipment that a 240 uses in that regard.
1.8turboterror wrote:I would love to buy a nice manifold where my turbo sits up front behind the headlight unfortunanetly nobody makes one
That's just silly. Bad design.
1.8turboterror wrote: i am stuck wit the garbage on ebay that crack i know this i would def be willing to buy a good manifold. what bout a thinner brake booster is that a possible solution ?
I don't think so.
Also, some eBay manifolds are not bad if just take the time to de-burr the inside of the tubing and modify some of the mounting area to make it easier to install. You pay, what... $150 for a nice eBay manifold from XS Power or whatnot these days? Probably not even...
Sounds like you should really get around the CA forum a lot more, really...
