Thrwnsprkz »
https://forums.nicoclub.com/thrwnsprkz-u15288.html
Wed Apr 20, 2005 8:35 am
B&M... there is no replacement, its simply the best and worth every penny
I got mine for 179 shipped from Injected performance (nico sponsor)
yes it buzzes about 5k... but I'm not in the 5k range unless im on the track... so I dont mind, plus its a resonation noise, so it accually fairly accurate... I always know when I hit 5k
the shifter is firm and SHORT due to the springs and it almost does the shifting for you around 3k rpm if you put the clutch in.
C's, Pilot, Megan... nothing is similar, took about an hr and a half to install... just b/c two of the bolts are a pain up on top of the transmission, just lower the transmition bolts a bit and it isnt that bad.
if you want a SS get a B&M, you won't regret it
