07V84Z »
https://forums.nicoclub.com/07v84z-u92083.html
Tue May 20, 2008 10:13 am
I had an idea for the "Quick and Dirty" method. I haven't worked out all of the details yet, but basically if you just cut the shifter to the desired length and put the shift knob on there, you're golden. BUT! In order to shorten the reverse lock-out lever, you need to cut a section out of the middle, then re-connect the two pieces. Or, if you have the resources to make a mold of the lever itself, and then just shorten the mold...cast the mold in plastic...and voila! A short shifter is born. I guess if you don't feel like making the reverse lever shorter, you could just cut it, and somehow make it a stand-alone piece. Like just have it down next to the shifter, with like a ring or something that is easy to grab on top.
I dunno, just some ideas I had about shortening the shifter. Even though, shortening the shifter itself, doesn't actually shorten the throw because the pivot point is the same. But still, the lever would be shorter, and if that's what you're after...then there you go.
