Short Throw Shifter Help
bigplayer2382
Car: 2010 Nissan Altima Coupe S 2.5
So I was installing my Short Throw Shifter from raceline, and I was at the part where it says 'gently pry off the cable from the pivot joint'. Most people say 'yank on that mother ****er' but I actually went the gentle way and was doing it gently, after about 2 minutes it popped off... bent... when I pushed it back on later, it went on very smoothly..... and broke.... Sooo Now I'm kinda screwed, Is this something that I will be able to fix, or is this something that I'm going to need to take to a dealership to get fixed? I've heard about people breaking it before and I'm curious what they did. Here is a picture of it
edit: I'm not sure if this helps any, but the car only has 14k miles on it.
bigplayer2382
$100 for the part.... $120 for the labor... will be done friday.. I appreciate all the help
RicerX
Car: '20 Titan Pro4X
For future reference, you might have better luck posting in the coupe forums to get faster responses man! Sorry you had trouble with the STS.
