As far as lubrication - I'm a big fan of pulling the injector fuse and then turning over the engine for a few seconds before the first start-up. After seeing how fast that oil pump can spread oil around through the system (watched Byron do it with the front cover off for the guides on Q2) that should make a huge difference! I even hate to hear the engine tick two or three times after an oil change so I use that trick then too. I used that method on "Q2" after it sat for 6+ months without being started and heard zero rattle!
I couldn't get Byron to let me pull the fuse and turn the engine over after the guide work - even after several requests he "forgot" - he was probably just pissed that I had been looking over his shoulder for a day and a half and ready to get me out of there ASAP.
In any case Byron said it still made a lot less noise than the other Qs that he had done - probably because of that little bit of priming by turning the pump the day before... That's not part of the normal service since it makes a bit of a mess. Seems that it's some sort of right of passage at T3 to hear the chains slap and rattle like hell on the first startup until the tensioners are pumped up. Whatever... I like nice quiet engines but they're the pros.
What I'd really like to see is some sort of 12v driven auxilary oil pump that could do the same thing before each startup - sort of like the fuel pump starting up for a second when you turn the key on. I've heard that someone did a study on engine wear, and found that one cold start-up causes as much wear as a 50 mile drive, or something like that... maybe Dennis has more info...
Heath
