Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Oct 19, 2004 6:36 am
The following graph shows the resistance of the Nissan coolant temp sensor vs. temperature. If you study it you will see that each 1F is ~~ 3.75 ohms [+-] at around 176-195F but each sensor is slightly different so a 25 ohm variable resistor [NOTHING LARGER] in series with the sensor should allow you to ZERO in on a 6-7 F readjustment range.
What I use is a fixed resistor in series with one lead of sensor with a toggle switch* to short the resistor out for cold weather use........the coolant must get to [read] 176F for the ecu to be happy.
DON't get greedy and blow the engine from fooling ecu too much.
Years ago BMW had a series of switches [in EURO models] which trimmed the ecu to adjust for Summer/Winter fuel/ regular fuel, what these did was vary ignition advance and coolant temp and fuel enrichment: Zero, -2%, -4%, +2% +4%.............6 slide switches tuned the ecu for German or third world fuels and temperatures...............all this went away with OBD1 in 1985.
You must know exactly what the ecu is reading as the coolant sensor temperature!
