hahaha this is home depot sh1t guys...
"what did you use to connect the pipes together, and where did you get them?"
me and dave cut the rubber from the stock intake that was connected to the throttlebody... cut it in half you can use both ends. or if you dont wanna be that cheap you can goto Discount Auto and pick up throttlebody intake adapter rubbers. (make sure they are extra ribbed for her pleasure)
hehehehe
"any difference in performance?"
acutually i have noticed alot better throttle responce, and for some reason when me and dave did a lil race he usally walks me from the start, but i kept with him for a lil bit then he slowly started pulling.
ill keep ya guys updated on the cheap a55 project
-Jeff
I am planning on cutting up my S13 ebay intake and making the cold air extention within the week. the filter will then be wheer the window washer fluid box was. We removed it seeing it never worked anyways. we already have the hole cut and you can see the hole if you look at the third pic (its at the end of the red filter
