I apologize for being so long winded. Feel free to reply with any suggestions or corrections. Thanks.
Pics are like 1024x768 I think, right click and hit "View Image" (Firefox) to see it bigger if it's not that size.
Prerequisits Have moved your battery to the trunk.
Difficulty Easy (hell I did it, that should show how easy it is)
Supplies 3" aircraft clamp (or two put together like I had to do) 3 1.5-2" aircraft clamps 2 small breather filters (optional) a few zipties stuff to plug the hoses and holes TFE Paste with Teflon (sealant) found it in garage 1 of these atleast (2 if you're going to leave the valve cover hose on your intake)...
1 of these if you're going to leave the little hose on your intake...
Tools Dremel Drill (1/2" bit and 3/8" bit) Knife
How my engine bay looks as of writing this (working on getting rid of the AIV)
To start off go ahead and remove the stock intake. Take off all the hoses that connect to it. There should be 5 hoses.
The big one on the bottom goes to a resonator and it makes it easier if you go ahead and remove that. You can leave the box in there but getting the hose out of there is recommended.
The next hose to deal with is the one coming off the valve cover, you can see in the picture I put a small filter on it, however, you can plumb it back into the intake if you don't want to pay for the filter. The hose connected to the rubber peice between the throttle and the intake. I went ahead and plugged that up. And yes I used a pencil wrapped in duct tape and then used an aircraft clamp on it.
The hose coming out from underneath the intake manifold must stay on the intake, if it's off, my car would idle but if you revved it, as soon as the rpms started to fall it would just stall. (should be part of the AIV system I belief) I used an aircraft clamp on it because it had a bad bend going back onto the tube so I wanted to make sure it wouldn't leak.
The small hose on the bottom deals with the AIV system. You can leave it on the intake if you are keeping those otherwise you can go ahead and just remove all those. I left mine on but am looking into removing that stuff, will post an update if I do. (I took this off and plugged this connecter. It only deals with a line coming from the AIV, if you remove your AIV system you can plug the hose that comes from the intake manifold that T's into this smaller hose and the hose going into the AIV on the other side of the engine. I just plugged it with a screw.)
The last hose to deal with is the one that came out of the intake box on the exhaust side. I put a breather on it but you could just remove all the AIV stuff. I'm planning on trying that later.Here's the link to remove the AIV.
zerothread?id=26150
That will take care of the hoses. The next thing to do is go ahead and cut the bottom off your intake box, I did a sloppy job with a knife and then went back and used a dremel later on. I recommend just using the dremel all the way around it.
While on the airbox, you should plug up the hole the AIV went into, won't effect the car but it does run a chance of letting you suck something in since there's no fitler there. I had a little cap in the garage that I used. It was a little too big so I wrapped the hole in ducttape, put the cap over and then used an aircraft clamp.
Now go ahead and cut a hole where the battery use to be. I had to cut through the tray and rip up that spot, then I cut through the piece under that after. Sadly the battery tray was harder to cut through then the car.
On my car the wires connected to the MAF were wrapped, so I had to cut the wrap open about half way so I could fold the wire back around to the other side.
Now you can get an idea of how your intake will sit so you can begin to cut the stock intake tube. Also, I recommend loosening the clamp on the radiator hose to let you twist it. If you twist the hose around a little you can have it bend down to let the intake sit ontop of it and still have almost no crimp on the hose.
This doesn't have to be perfect since the rubber coming off the throttle will allow some movement. I would say to use the end that came off the maf side of the intake. I used the other one because I wanted to keep the big hose hole, I didn't know I could get rid of that, at that time I had no idea where the hose went and thought it was for the A/C or something. Obviuosly since I did my differently it will look different than yours, but yours should be cleaner. Go ahead and test fit so that you can get an idea where on the intake you cut, it should just be a little after the bend. After that I'd say cut a little bit past where you thought.
From here go ahead and test fit the piece, it won't be easy but you can shove that end into the rubber piece coming off the throttle. Go ahead and cut and shave the corners as necassary, but do not let any grooves in there, it has to be smooth so the rubber can make a seal. Since this piece is not a circle, use the 3" aircraft clamp and get it very tight, the clamp should take the shape of the intake tube to make a good tight fit.
By the way, the big plastic cap on this is for plugging up the big hose, however, you shouldn't have to do this since you won't have it on there. Plus you won't have to use another clamp to attach the flexy piece that connected to the maf to the intake hose like I did.
You will need to drill 1 to 3 holes depending on what you keep. The hose coming off from the bottom of the manifold is a must and I used a 1/2 drill bit for the hole. I also connected the small hose from the bottom which I used a 3/8 bit for the hole. For the AIV going back into the intake instead of a breather, I'd say go with another 1/2 hole. Apply some sealant and screw in the little connectors.
Now go ahead and hook up the intake like normal. Plug the hoses back in to make sure they fit snug, if the little normal rings don't hold it on well enough use an aircraft clamp. Also, ziptie any wires or hoses to get them where you want (mostly away from the fan for me). Adust the radiator hose to have it underneath the intake and with no obvious crimps. RETIGHTEN THE CLAMP ON THE RADIATOR HOSE!!!!
Go ahead and start her up to see if there are any leaks, definitly fix those if there are, however I didn't have any.
This was done in notepad so I don't care about typos and I'll make edits about the hoses as I explore them today.
I'll try to get a stock intake pipe and redo it the better way that I wrote in this, instead of the way I did it so I can show pictures of where I cut and stuff. Assuming I find an intake pipe by tomorrow.
Stuff I took off (fan shroud)
Modified by madbouncy at 11:24 PM 5/29/2005
