short in my ignition subharness or bad coilpacks???
loudbay
Car: duh
so i'm doing another install, and for some reason, i'm getting 12v coming back from the coil packs to the output side of the ignitor.... these wires should be 0v or less than 1v (just the ignition signal from ignitor). when the sub harness isn't plugged into the coil packs, the 12v isn't there... so my coilpacks are (for some odd reason) connecting their 12v power source to the signal wire from the ignitor chip.... my voltage from the ecu to the input of the ignitor is normal.... i'm sure that this is not healthy for the new ignitor either.... please help if you can....matt
oh, the resistance from terminal a to terminal b in my coil packs is 1.2-1.3 ohms.... i think that this is fairly normal..... but i also have full continuity between the same 2 terminals.... can any tech guys confirm or tell me mine are bad?!!??!!??!!
Cyberkreig
Car: 1993 Nissan 240SX SR
