Structure240sx wrote:if i was to pick up a stock flywheel can i jsut drop it off at a machine shop to have it resurfaced and drilled/tapped? how much would this cost about?
Well... I took my stock flywheel and the 240mm truck pp to the machine shop and I said: "Need to resurface this (FW) completely and be able to screw this (PP) into this (FW)"
They resurfaced then measured out the pp, drilled new holes for the pp bolts into the fw and moved the little retainer on the fw to it's new location. Took them about 1 day to do it... cause they were backed up. It runned me $36, including a second trip to the machine shop to have the contact surface resurfaced another 3mm to have the diaphragm lay completely horizontal once the pp was installed.
I'm pretty sure that it won't cost you that in the US, but it never hurts to ask.
Quote » i still think i will just go with a act xtreme seems to be the best bet [/quote]Isn't there a 240mm ACT extreme clutch? For the 300zx or something. Although the 225mm would be cool too.
Just want to give you more options
, so you may debate on it for couple more days and loose sleep over it and... :pface I know I did
