Darius wrote:Why AEM for the fuel pressure regulator?
i had one and it work fine
Darius wrote:Are you planning on recirculating your BOV? Since it's difficult if not impossible with that BOV, prolly not. So I'm assuming you're going to run a blow-thru setup. If so, are you buying a new intake manifold or are you just going to fab up some piping to the stocker?
yes i will be runing a blow-thru ste up and i will fab new piping to the stocker
Darius wrote:What about replacement parts like water pump, timing belt, and pulleys?
yep they are all in the list just normal maintenence so no need to list theme
ps: Darius what set up are you using
thx
